Refrigeradores
Whirlpool No Frost Wrw51 Refrigerator - Too Cool
sebas_t
I have a Whirlpool No frost, model WRw51x ACLARO, I'M NOT TECHNICAL IN FROST OR NOT MUCH LESS, but I can manage to fix things ... I'm gaining this ort * refrigerator, I hope someone can help me ... There was a time that did not cool, was that the plate had ruined, change the plate. I did not put the original, it lasted little more than 6 months, it broke again, I put the original, I worked OK for a while. Then it started to cool too much. change the sensors. (This would have been a year ago). Neither had originals at the time, so I decided to put the orignals, it was OK again for a while (let's go for about 1 year) - Now it started to get too cold again - I opened it several times and there is no ice behind or there is very little) - that is, I understand this OK However ENFRIA MUCHO, in the refrigerator, many times things are frozen, milk, water, dairy, from time to time congeal, even the dispenser of water. BUT IT ACA THE RARE, happens from time to time, NOT ALL THE TIME. The other time we went for a week and expected to find everything hard and frozen upon arrival, and yet not, all normal ... however, the next day, the water from the door dispenser, frozen My cannibal solution (which obviously does not work) was to cover half of all air outlets, to reduce the cold ... but as I said, it does not work. I also doubt that it will do the refrigerator well. I notice something, that the phenomenon is more, but not EXCLUSIVELY, when the freezer is fuller. The regulator of the refrigerator is at minimum (1), in the freezer is also at minimum. I'm buying another set of sensors? Where can the problem be ??
omorma
omorma
15.708
Hi how are you, the problem can be in the damper that is locked or open and does not work, you should disarm the conduit that is in the bottom of the refrigerator remove the damper and place the bulb on ice and check if it closes when receiving cold, when you disarm the damper marks the position of the plastic gear to put it back in the same way, regards.
sebas_t
There you killed me ... I have no idea what is or where the damper, much less I could tell you the subject of gear position ....
omorma
omorma
15.708
In the back of the bottom of the refrigerator there is a conduit with holes and a palaca or wheel to place minimum or maximum is also the light inside that conduit is the damper
sebas_t
!!!!! I THINK IT WAS THAT! .
Find the damper.
I took it, (there was a piece of jammed telgopor) - I put the bulb in a cold gel and closed the door.
I'm optimistic. THANK YOU VERY MUCH. I wish it was this.
omorma
omorma
15.708
It was that that locked the damper and not closing let the cold pass
4.52
(63)
Elkin Fernández
Agustín Belen
