Aire Acondicionado
maq. ROCA Mod. BCH 15-38 / E
AE
AE
AE
10
Hi, I have a problem in a maq. ROCA a little old, starts the compressor and a few seconds to, in a matter of two minutes starts again and returns to stand, is good gas and the central plate is blinking the led 2 times, I have no manual and I do not know which corresponds. Thank you
malevolo2020
Good afternoon, check the temperature sensor, possibly this bath of resistance that is why you turn the equipment off. here you can learn how to try them
JoeFranco
Also you must check the electric consumption, there may be an excessive consumption and for that reason for the compressor, check electrical connections ... I hope you use something the comment. Regards!!!
4.52
(63)
Elkin Fernández
Agustín Belen
