gracias amigo pero sigo sin entender, te copio la especificacion de la pagina donde lo consegui y es el que me gusta, por favor si puedes explicame...
este es el link, hay veras que es 115 volt, no se si me equivoco.
http://www.compactappliance.com/DPAC120068-Danby-12000-BTU-portable-air-conditioner-ac-a/c-3-in-1-comfort-dehumdifier-fan/DPAC120068OB,default,pd.html?mtcpromotion=Pricegrabber%3eClearance_Items%3eOpen_Box%3eDPAC120068OB&src=PRICGRAB
Model: DPAC120068
Brand: Danby
Air Conditioner:12,000 BTU cooling capacity
Cools 300 to 425 sq.ft. (depends on heat load)
Dehumidifier: 70 U.S pint per 24 hours (33.1 litres)
Fan: 3 fan speeds - High(485CFM),Med(380CFM),Low(300CFM)
External bucket capacity: 31.7 US pints (15 litres)
Warranty: 1 year limited warranty
115 volts, 1200 Watts, 10.5 Amps
12,000 BTU Danby Portable 3-in-1 Home Comfort System
Electronic controls with remote control
Oscillating 4 way air direction
Direct drain option for continuous operation (hose included)
Variable electronic temperature control 16° C ~ 31°C
Quiet operation
Castors for easy portability
Weight: 112.4 lbs.
Dimensions: 33 11/16"h x 17 1/2"w x 20 1/16"d
