Measurement tools
Multimeter baw ut 330
rodriguezjuancar21
Good morning, I have a multimeter that starts turning on the buser and does not stop unless I turn it off, change the battery and continue the same, I would like to indicate what it can be and if it is worth fixing. Cheers
Claudiogol
Claudiogol
3.027
You have a short circuit in the input circuit, they are very small components and not anyone can replace them. If you need reliability in the measurements it is best to replace it and look 3 times at what scale you are measuring.
rodriguezjuancar21
thank you very much Claudio
