Economical multimeters do not bring additional protections to fuses.
If you find a burned R, it is certain that it has a short circuit of more than one component. Because its power is designed for normal current consumption.
A few years ago, I saw an economic one die from measuring higher voltage than specified.
Thanks for your opinion friend servimat1, I have already made the measurements to the smd resistance components and they give me the corresponding value, but it has some smd counters and a ceramic one that I have not been able to measure them, if anyone has any suggestion to do the tests to those components, thank you.
