Measurement tools
digital tester lumistar brand burned resistance
Francisco javier Briceño
Greetings friends, the problem is the sig. I have a lumistar mod digital tester mod. testo2 which burned the resistor R 22 and I don't know what value it is if someone can tell me what value it is or can you give me the diagram of this digital tester thanks in advance
oswaldo A 2016
tell me the serial of the platelet or chasi
Thanks friend, all I see is the sig. - l15038A in another part of the chassis the following appears. 15 11 08
oswaldo A 2016
greetings Francisco the r22 is a r9000 its value is 900ohms you can also place a common, white, black, brown, gold, it is confirmed since I opened one of the testers that I have similar to yours luck comments and values we are at your service
thanks friend, Oswaldo A 201 is the solution we are at your service
oswaldo A 2016
Likewise, we are in order to sierre the post to serve other fellow friend
problem solved
