Measurement tools
RadioShack brand multimeter see me hurt just beating
carlo rodriguez
How to repair it already check resistance and apparent are good
Hi. Did you connect to voltage while on resistance scale? If the discrete components look good the problem must be in the micro and this is not solved. Regards
electricodavid33
Hello Carlo Rodriguez, unfortunately so you say , did some measurement on the wrong scale, for example measure voltage on the OHMS scale, (RESISTANCE). Low quality multimeters do not usually have any type of protection against these errors, and the consequence is of being inoperable. For damage of the microprocessor, which has the form of a black drop in the IC Multimeters of good quality, usually perform a series of beeps when detecting an error of measurement or incorrect scale. What you can do is disconnect the buzer, and see which of the scales works correctly, obviously by performing comparisons with a multimeter that works correctly.
carlo rodriguez
Thanks for the help and ask what the buser is
The buzzer is the element that gives you the beep. It is usually round cylindrical black.
