Measurement tools
calibrate multitester UNI-T UT55
Eumar Antillano
hace 6 años
hace 6 años
my multitester gives me ghost readings and I have read that the calibration is calibrated or lost and I uncovered the multitester and I observe several trimmers identified with VR1-VR2-VR4-VR5 and VR6 I do not dare to move them because I do not know that modify someone will have an idea or know calibrate and can support or if you have the diagram I think it can also work. I grab any support in advance, help.
Rolando Loayza
hace 6 años
hace 6 años
To calibrate a tester, you will require a standard calibration standard of around USD 15,000 or more, depending. The most logical thing is that you send it to be calibrated in a METROLOGY laboratory, which have the calibration standards for each type of instrument.
