Hello, how are you? I have the following question, I don't know if it is better to buy a clamp to design terminals, specifies for a single type of terminal (brass, bare, pre-insulated, tubular toecaps) or purchase a kit consisting of a single clamp with interchangeable heads with the shape for each type of terminal, I have the vague idea that if it is for a specific use it is more durable and one can apply more force and if it is the clamp with interchangeable heads it is weak or susceptible to fail, lock, just It has the advantage that it is very practical, the most common work I do is on cables ranging from 1.5 mm2 to 10 mm2, what do you think is better to buy, the kit costs the same as three or four specific clamps, I work mostly with tinned copper tubular joints and tubular tips, just that, I never use brass or pre-insulated terminals. Greetings and thanks in advance for your answers.
