Industrial electricity
single phase water pump
ruben1289
I have a single-phase motor, my question is, can the single-phase water pump be connected to the line of an industry that is three-phase?
uliher
uliher
552
if you take the neutral and one phase is 220v
elektomaq
elektomaq
62.202
Hi that will depend on 1) three phase tension 2) the nominal voltage of the pump If the three-phase voltage and the nominal voltage of the pump are equal, for example three-phase voltage = 3 × 220V, nominal voltage of pump = 220V, then you must take 2 phases of the three present If the three-phase voltage is 1.73 times higher than the nominal voltage of the pump, for example three-phase voltage = 3 × 380V, nominal voltage 220V, then you should take any more neutral phase. If the neutral is not available, you should ask the company to download or place a 380 / 220V transformer, which may be more economical to replace the motor with another three-phase Cheers
