Hi. It is as you say. The parameters to take into account are, among others, speed and power. Keep in mind that for a conveyor belt or for an elevator speed gearboxes are used. These apart from reducing the speed increase the torque of the set. For example. If you need a 1 HP motor to move 100 Kg on a conveyor belt, it could not develop full speed since it would be a catapult instead of a belt. By placing a motor reducer, the engine power would be 1/2 "HP for example since its torque would be increased by the reduction of RPM. This is because with the internal gears and endless pulley system is achieved. Toothed but pulleys at last, this is just a mere example, it has no real validity.
