Industrial electricity
Transform three phase motor to single phase
lucho
lucho
116
HELLO, CAN YOU TRANSFORM A THREE-PHASE TO SINGLE-PHASE ENGINE FROM A TWO-PAIR ELEVATOR OR DO YOU HAVE TO MODIFY SOMETHING IN THE WINDING ??? THANKS
Ennio Montenegro.
The three-phase motor could be operated with single-phase, but loses torque and power. It is preferable that you do it rewind although there are frequency inverters that are fed with single phase and have three phase output, but it would be much more expensive.
elektomaq
elektomaq
62.202
Hi I would say that for that specific use, you can't, the elevator comes with the engine calculated for the necessary force, if you lose part of your force, doing the same job, the engine will inevitably burn Anyway, in the manual section of the motors and windings forum, this is how it is done, although I repeat, it can only be done if the engine will be exposed to a much smaller load than the original https://www.yoreparo.com/es/motores-electricos/manuales/5773814/convertir-motor-trifasico-a-monofasico Cheers
chispa41
chispa41
209
Right now, engine prices have dropped significantly. I would take the motor nameplate, (kw, rpm, etc.) and look for a single phase equivalent.
elektomaq
elektomaq
62.202
It is a good option as long as the machine allows assembly due to single-phase equivalent motor dimensions as it will be larger
