greetings janhi brito ,, you must indicate if the motor supply is 220 volts or 440 v0lts
-also indicates if your engine has 6,9,12 points ,, since some equipment is configured to star or double star and it is not possible to use some controls
- for example, if you have a 440 or 380 volt motor and that is the line voltage
--- you only connect tips 1,2 and 3 in force contactor output ,,, and tips 4,5 and 6 in the part where delta star wiring are joined
