If what I want is to protect my transmitter for now! he is the one that constantly turns me off about the ups is in 6 months I will connect it and turn it on so that my transmitter protects me. For now it is protecting my transmitter.
SO IS ! FOR NOW IS TO PROTECT MY TRANSMITTER FROM THE ELECTRICAL NETWORK AND ITS TRANSITIONAL OR DROPPED PEAKS OR ELEVATIONS BECAUSE THE TRANSMITTER DETECTS AND PROTECTS AND TURNS OFF. THEN I HAVE TO PLACE OR INSTALL WHILE BOTH IN 6 MONTHS I CAN ALREADY PLACE MY UPS THERE ON THE HILL FOR PROTECTION.
BECAUSE THE UPS IS POWERED WITH THREE PHASES AND NEUTRAL / EARTH AND ON THE CERRO FOR NOW I ONLY HAVE TWO PHASES AND NEUTRAL / EARTH THAT IS WHY I CAN NOT TURN ON MY UPS UNTIL THE ELECTRIFIER TAKES ME UP TO THE CLOSE THE OTHER PHASE TO TURN ON THE UPS AND ON THE OUTPUT CONNECT MY TRANSMITTER ALREADY AT 220 VAC
agustinp
IT RESULTS THAT THAT UPS IS POWERED IS WITH THREE PHASES AND ITS NUMBER OF THE CONTRARITIES DOES NOT TURN ON AND ALREADY ON ITS OUTPUT I ONLY USE TWO PHASES TO FEED MY TRANSMITTER
BUT THERE ONLY FOR NOW I HAVE TWO PHASES AND NEUTRAL OR EARTH AND THE TRANSMITTER IS DIRECT TO THE NETWORK FOR THAT I AM LOOKING FOR SOMETHING THAT PROTECTS ME FROM THOSE FAULTS FOR 6 MONTHS ALWAYS WHEN I HANDLE 30 AMPS PER PHASE
Milton
When powered by 2 phases of 110V, the current is 30A. It is the same current that enters through one phase, which returns through the other phase. It is the same to say that 30A circulates through the phase and the neutral.
The power is 6.6 KVA.
Good morning, and cordial greeting Don Ennio, I have told you that the energy on the hill does not go away! If we do not believe that the fact that the transmitter equipment is protected is not due to lack of voltage. if not by transient peaks in milli-seconds or that something suddenly happens in the network and that is why it is detected by the transmitting equipment and protected, it is not because the energy is fenced for minutes or for hours not.
What you say is true if the energy goes completely the ups go back to backing otherwise not.
so I'm looking for something that protects me each phase or a phase that is only 120 Vac
