Industrial electricity
Cold room electric board
alxxx
alxxx
45
I need to design or assemble electric panel cold room low temperature ..- 18 degrees Celsius, 5-horsepower compressor, defrosting of electric resistance diffuser, danfost dijital controller .... someone could collapse me with a functional scheme, or diagram ... .Thank you
elektomaq
elektomaq
62.202
It is important that the panels and electrical installations are made by a professional electrician and not by the refrigeration
You have to know how to separate the boundaries in the different trades and professions. It's as if your dentist resets a heart medication
Ennio Montenegro.
The control panel and the temperature indication should be outside, not inside the cold room. I imagine they have to enter when there is a fault or know the temperature inside to adjust it. Needless to reiterate that a professional should do it.
Hi. You should give more information to help you as if the compressor is three-phase or the resistance of the resistors. However, will you do the job? Regards
alxxx
alxxx
45
Three-phase compressor 220 .tres resistors 220v ac, fan motors 220v ac, controller 220v ac, contactors 24v ac ...
All cold room boards go outside exclusively. What I advise you is to turn to a professional to avoid problems. Regards
alxxx
alxxx
45
The control panel is not going to be installed inside the camera is not necessary ... I was simply asking about an electrical scheme for this application
