Thanks for your answer.
Could it be that a speed regulator with 220ca input and three-phase output is marketed?
If there are with 220V single phase input and 220V three phase output.
If your motor is 220/380 three-phase, you connect it in delta to 220V three-phase.
The link shows one of that type.
https://es.aliexpress.com/item/220-V-1-5KW-entrada-monof-sica-y-220-v-3-salida-convertidor-de-frecuencia-velocidad/32842076445.html?src= google & albslr = 201998564 & ISDL = y & aff_short_key = UneMJZVf & source =% 7Bifdyn% 3Adyn% 7D% 7Bifpla% 3Apla% 7D% 7Bifdbm% 3ADBM & albch = DID% 7D & acnt = 494-037-6276 & albcp = 913280151 & albag = 47655558845 & slnk = & TRGT = 298446817103 & plac = & creates = es32842076445 & netw = g & device = c & mtctp = & gclid = Cj0KCQjw1-fVBRC3ARIsAIifYOPkisf7f6qW
