I am from Peru and different voltages are handled (220,380 and 440) do not have a control or a specific sector for the distribution of tension for the industry and try to distribute between industries and homes, but my doubt was basically the transformer overload as a root problem of the low voltage, in this case, would the transformer have to be changed or what has to be done?
No Alexander, first you have to see if these transformers have the maximum tap, if you have to change them. The tap is a bridge that changes place to increase the tension provided, but has a limit and if it is already in the limit, if you have to change the transformers (the 3) for more powerful ones
