Greetings and thanks for your contribution to my concern.
Edgar Omar Benitez,
The truth is, you have understood me well and I find your explanations
NOW IN YOUR COMMENT.
"If you only have one phase (L1) to feed the primary of that transformer, surely the other power conductor is the Neutral. Now, in the secondary of this transformer, you only have two wires, in which you will measure between them 220VAC (SINGLE PHASE) therefore you have no way of having a phase shift in the output cables of that transformer.
From what I understand, it would be two phases, Repeated but No
Continuation of the previous comment ...
As I was saying, there would be two phases one for each cable that comes out of the transformer, as you mend it, but these would not be outdated, but rather distributed,
As Servimat1 mentions in a previous comment,
I would like, you can corroborate this ...
First of all, Thanks...
Regards, Servimat1.
Let me focus my doubt,
I have only L1 380v of high voltage that enters the transformer and at the output I have 220 Single Phase divided into two phase, phase cables.
The question.
Is there a phase gap between the output cables of the bone transformer phase, phase, 220 phase?
Thank you.
