Industrial electricity
Three-phase sensitive machine connection
panda93
panda93
19
hace 6 años
hace 6 años
Hi guys, does anyone have any connection diagram to a sensitive three-phase motor with emergency stop, I bought a montero contactor and two auxiliaries [img] https://adjuntos.yoreparo.com/imagen_post/0004/64/d11cada50c2f58b0512e5263e4a5e0dbe90b20b9.jpeg [/ im
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello A sensitive saw (or other sensitive machine tool) due to its operational characteristics can be turned on with a three-phase rotary toggle switch. It makes no sense to arm a command with contactors and keypads. In the case of wanting an emergency stop, you do not necessarily need it to be on time for the machine, since it is more useful for it to be the tension of the sector involved in the accident. I tell you my experience at that point. The owner of a medium-sized metallurgical factory called me because I wanted three emergency stops that cut the tension in their machines with a fist bump located in strategic places easily accessible from these three sectors. The conditions: something simple and cheap. My solution was to place a PVC box of 7 cm x 7 cm x 5 cm in an accessible column (or wall) where I placed a fist bump without retention (large red button), I carried a phase of the feeding circuit of the machine (not lighting) and the grounding wire, inside the box I connected the phase to the push button and from this to a common resistance of 3000Ω (I think) of a couple of watts inside a connected glass spagetti at its other end to the grounding wire; The operation is simple, when pressing or hitting the stop button the phase is grounded through the 3k resistor and the differential circuit breaker jumps. This stop is done to verify safety when the last shift ends each week. [B] So with two pesos I made the machine stop. [/B] Today, if I did that job, I would place a 5 m mignon common lamp instead of the resistor and cut the pvc box and make it a window to see the light (if the lamp is on, it indicates circuit breaker failure differential and requires cutting of the board) I hope someone serves, if there is any doubt I add information. This system operates the circuit breaker where the live circuit has been taken.
panda93
panda93
19
hace 6 años
Hello sensitive nastor to cut irons. Since you use operators any accident that activates emergency stop that is why I wanted the diagram .. the three-phase schndeider contactor. I have the diagram but the price is very high. And the most economical montero contactor. I wanted to do it. With that
nastor
nastor
17.232
hace 6 años
Hi Panda. I am going to tell you about an economical solution for emergency stop at factories. I edit answer.
panda93
panda93
19
hace 6 años
Very good information You would have a diagram to do. Mc2. 32
nastor
nastor
17.232
hace 6 años
Let's see if you understand.
hace 6 años
hace 6 años
Hi. The only requirement you have is to be able to activate it from a trigger on the handle of the machine. It can be a "common" button that is NA. What if, being only a button, an emergency stop could not be placed since when you release the button the machine will stop. As for the connections you must enter with the three phases through terminals L1, L2 and L3 and exit through T1, T2 and T3. The coil has two terminals (A1 and A2). One of them is connected to one phase, and the other will pass through the button taking voltage from another phase. The contactor coil must be 380V. If you have bought one of 220V you must use the neutral for its connection. Regards
Javiier2001
hace 6 años
To make it an emergency stop, you should have a brake so that it stops turning instantly because, due to inertia, when the circuit is cut, it keeps turning.
panda93
panda93
19
hace 6 años
Thank you very much some diagram
hace 6 años
You do not need any emergency stop circuit. Simply place a push button with a lock called "mushroom head" in series with the power supply of the contactor. Pressing it will open the circuit and mechanically lock. To start it, you just have to turn it halfway with your hand and it will unlock. If you upload a photo of the machine we can tell you the best application. You may need a circuit with a self-locked contactor.
