Does it mean that having sparked the red contact with the black I have damaged it? After that test I have only measured with tester without reconnecting
tension. And in fact there is a connection between red black and between orange black or orange red nothing connection. This indicates that there is still life in the valve? Cable to test phase to black and neutral to one of the wires of an incandescent bulb the other cable of the bulb connected to orange this should cause the valve to close the water passage and to remove the bone tension when disconnecting either phase or neutral Should it open again?
Thank you very much right now I take the test and comment. Try as we say here in Venezuela to sparkle to see if the closure was activated with the black and red wires the black connected to the side of a plug and the medium red making contact but the result was a huge spark. And he didn't convince me. Thanks for the opinions and help
