Industrial electricity
Parallel electrical wiring
xperiencess
hace 6 años
hace 6 años
My question arises since I just bought a JD Golud solenoid valve the M-3V model which brings the dual voltage coil the problem comes when trying to wire it. I read clearly in English that says: "FOR 115 VOLTS WIRE PARALLEL RED AND BLUE TO LINE YELLOW AND BLACK TO LINE" the big detail is that I don't know if I should wire red and blue together to the positive and yellow and black to the negative or if it is only a couple of the cables mentioned, is it red to positive and blue to negative without touching the other two or vice versa yellow to positive or phase and black to neutral without connecting the others? who advises me as clearly as possible please and in advance thank you.
JOSE MIGUEL SIRGO PASCUAL
hace 6 años
hace 6 años
It is clear that for 110 v, red plus blue are connected on one side and yellow plus black on the other.
xperiencess
hace 6 años
It may be almost obvious but before spoiling the sensor I preferred to ask the questions and advise me, thanks for your opinion
hace 6 años
Connecting a single winding is still 110 V working voltage but the power would be half. For another occasion when you are not sure, use an incandescent lamp connected in series and if everything is correct you have to turn on the filament very dim. If it turns on emitting a lot of light it indicates that the thing is wrong.
xperiencess
hace 6 años
Thanks man I like to learn and expand my knowledge. I consider the issue resolved. by chance do you also know how reed switch works? I have another open question of a gems fs200 valve if you want we can analyze and share to see if it can be solved.
hace 6 años
Reed is a very simple electric device.
