Industrial electricity
Three-phase inverter speed variator connection LS LSI 4015
maurog1120
hace 6 años
hace 6 años
good friends buy me this inverter that is old connect it and does not turn on the light of the frequency indicator and the power to the motor does not come out the input and output connections are fine but rst terminals of the yuvw power supply to the three-phase motor does not work
siste2016
siste2016
1.968
hace 6 años
hace 6 años
Hi Maurog1120, we will begin by making it clear that if the drive does not have the legend "rdy" or 00.0 Hz on the screen, it means that the equipment has no voltage, therefore it will not work, we will never do anything. Measure at the RST terminals, if they all have voltage, I mean if between R and S it has 380v. and if between S and T it also has 380v. If this is correct, measure in the small terminals that the equipment has, between 0 and +24, it must have 24vdc. If you do not have this voltage, it means that the equipment does not work because the power supply of the drive has broken down. In these cases, if we remove the housing, we can observe the presence of a fuse in the power supply, it is measured, if it is cut we replace it with another of equal value, we put the inverter on, press the RUN key and the motor must run. .
maurog1120
hace 6 años
hello colleague has no fuse neither internal nor external but I will check if the power supply comes out 12 or 24 volts greetings
hace 6 años
hace 6 años
Hi. for this and any drive to work you must connect the command or control part. You connected the power part. You may be missing a command like RUN or START. Do you have the user manual? Regards
maurog1120
hace 6 años
hello friend no I don't have anything on the drive don't turn on the frequency counter where the potentiometer is
hace 6 años
Therefore. You need to activate or turn it on.
maurog1120
hace 6 años
Can you give me an idea of how to do it?
