Hola lo que dice el manual es lo siguiente
SC400: Around the Drum
SC491 C5 D Bias Leak
A bias leak has occurred for the drum charge, development
charge, or transfer charge. PWM signals are sampled at 20
msec. intervals. This SC is issued if 10 PWM samplings within
200 msec. are abnormal.
 HVPS harness loose, broken, defective
 HVPS board defective
 AIO terminal defective
 Cycle the machine off/on
 Check all the harness connections of the HVPS
 Check spring-loaded AIO terminal installation behind the
HVPS.
 Replace HVPS
Creo que el problema es el cartucho de toner, prueba con otro
Suerte
