Household Electricity
Extend Installation 6 meters or more.
Diego Arlettaz
Hi everyone. My name is Diego and I'm new here. I just wanted to make a query since I didn't find it in the search engine or I didn't know how to search well. What I intend to do is extend the electrical installation to a workshop that I am assembling in my house (to connect some tools when I need) and that the installation continue another 6 meters or more until the end of my land, which I plan to do a Quincho later . The electricity consumption you will have will be minimal, since the lights and some refrigerator will be occupied, and not every day. As my knowledge in electricity is null, but I have already done some things here at home and I get along well. The problem that arises is if I can take out the Electricity from any side where the phase passes and neutral, and if I will have no problem being so many meters away. Or should I do some special installation with cables of certain mm? Thank you very much in advance!! Best regards! :) DSC_4408.jpg [988.30kb] [url=/ver-adjunto/aHR0cHM6Ly9hZGp1bnRvcy55b3JlcGFyby5jb20vZGVmYXVsdC8wMDA1LzMzL0RTQ180NDA5LTg2NTAuanBn] [img] /js/ckeditor/plugins/attach]
Hi. As you can get tension you can do it from any point where there is but this does not mean that it is the right thing to do. If it is for temporary and low consumption tasks, you may be able to take phase, neutral and earth from any outlet. If you are going to weld in a professional or semi-ideal way, an electric line would be ideal from the meter (your main board or board) to the workshop. You should do this with rlo with 4 mm² cable in the three conductors, a 25 amp differential (can be 40) and a thermal of 2 x 25. Greetings
Diego Arlettaz
Thank you very much for your answer! : D If I use a welding machine, an inverter, but very occasionally, for household items.
Thanks again! :)
