Household Electricity
two-wire extension for three legs
guigran
guigran
27
what function does the ground wire fulfill in an extension with three-legged chips?, the whole house has three wires from the pillar during the entire internal installation and javelin., if I manufacture a two-wire extension but with three-legged male chips And what happens with the devices that plug, are damaged? What is the function of the third ground wire for the devices?
elektomaq
elektomaq
62.202
The third cable, commonly known as land does not have any impact on the operation of the devices but if in the safety of using them in other words, many people were killed in electrical accidents because they did not have a system effective ground together with differential protection the fact of using an extension of only two conductors is canceling the protective conductor in everything that is connected in that extension, even if it has three-legged tiles and that your installation has the effective grounding, that is , it is insecure and you risk an electrical accident that in the worst case can be fatal Cheers
Maximiliano Diaz
Now that work is done by the therma and the circuit breaker and many who put the cable to ground in the house and do not serve it because they never put the javelin but that they solved it with the thermal that if there is a fault or you stay stuck that makes the cut skipping the thermal
elektomaq
elektomaq
62.202
Maximilian:
The protection cable alone is useless, having it without connecting it to a javelin or other type of disperser is worse than not having the protection cable
If you stay stuck, the thermal will never disconnect, the one that disconnects is the differential switch although this device does not prevent you from sticking and die electrocuted under certain circumstances
There are a number of rules to avoid a tragedy like this
The grounding system is one
The other differential switch
Envelopes and other mechanical barriers
