Thank you for your interest in helping me.
In my house there are two phases and neutral between the 2 phases measures 243 v
Since they gave me the house, I also noticed that when the washing machine is running, the fan goes down and the intensity goes up. But two years after I put the vacuum cleaner and a pressure washer, I realized that the TV turns off and as recently I bought the multimeter, I took the measurement and found that there is something wrong. I also have the doubt that if each sector of the house has an independent fuse because if I connect the vacuum cleaner to the patio, it affects the other circuit.
