Household Electricity
Physical Conductors Question
boston1686
Good Day, to All, I am making a ground installation which for the longest distance does not go to the thermomagnetic board but would make it to a beacon or copper rod, in the path of the conduit pipe that I plan to place are three climates of 7 amperes each (high efficiency). According to the table I occupy 12 gauge cable for each of the climates or of more caliber if I add the other climates, can I place an independent physical earth cable to each of the climates and that unblock the same oppressor of the earth rod? or the variila can only reach one cable. Thanks in advance.
Hi. What is your question? For the cable section or another reason? You must differentiate and separate the service land from the protection land. regards
btvíctor
btvíctor
27.259
Good morning servimat1 and best regards. Is it possible to open the subject of the following link: http://www2.yoreparo.com/electrodomesticos/lavadoras/preguntas/5726433/error-le-en-lavadora-daewoo-dwc-2000#post5726529?
The author of the topic hastened in his assessment leaving a contribution from which he expects an answer and it makes no sense to open another topic to continue with it. Waiting for an answer, Thanks and Regards.
It is not necessary to open it again. You can continue commenting on it as many times as necessary. regards
btvíctor
btvíctor
27.259
Thanks and Regards servimat1
A pleasure. regards
agustinp
agustinp
2.247
I interpret the query as if you don't know whether to arrive with several cables from each climate to the same rod or if to carry a single cable and splice and branch it I do not know the regulation of Mexico but in Argentina it would not be either. Each circuit with its therma must carry its ground wire .... on the board several ground wires are joined which are joined through a bar. From that same bar a thick cable is carried to the javelin For me it is the best that way because it doesn't make much sense to take several cables to the javelin
