Household Electricity
Various screws
Alejandrorocandio2015
Good morning ... I want to put together a box with screws for electricity. What do you usually take to a customer's house (sizes, models, washers, nuts, etc.) to make arrangements? Thank you
elektomaq
elektomaq
62.202
Hi What you always have to have: short and long frame screws module screw ivory head screws 1/8 x 8 and 5 / 32x 8 screw 6x 1¼ parking screws screws T2 T3 and T4 5, 6 and 8 mm studs with corresponding screws flat washers from 5/32 to 3/8 the amounts start with very little of each and over time you see what you use and reinforce the stock only there screws T2 T3 and T4 if you use them through (for example in light boxes) it is mandatory to cut and file the tip Cheers
agustinp
agustinp
2.247
it is not necessary to take a hardware store to each place ... with the fine thread screws of more or less 1 "in length that enter the thread of the boxes, plus some fixes of 5x20mm and some 6 or 8 shafts, and is
