Household Electricity
Motion sensor with led and photocell
Diegomar
Diegomar
214
Hello good night, I wanted to know if a Led reflector with motion sensor can work with a photocell of those used for low consumption. I don't need it to be a special photocell? Thank you
elektomaq
elektomaq
62.202
Hi Motion sensors usually have integrated photocell. If not, you can use any photocell with relay output Cheers
Diegomar
Diegomar
214
Hi, thanks for your response. The issue is that I want the motion sensor to be activated only at night so I connect it to a photo cell that shares it with two low-consumption lamps. So far I tried it and it works perfect. What I don't want is that I burned the LED reflector. In my father's house the Led reflector was as if blinking and does not turn on after a few months
elektomaq
elektomaq
62.202
Just for that they come integrated with photocell, to have the option that only works at night. It is usually adjustable through a preset identified with a sun and a moon. Adjust the preset closer to the moon and it will work only at night (you regulate it until you find the point), in that case the external photocell would be too much but if it works leave it as is
regards
Diegomar
Diegomar
214
Thank you
Diegomar
Diegomar
214
Thank you. What happens to me is also that sometimes it feels and sometimes it doesn't. I do not know why.
