Household Electricity
Kalop photocell connection with four-spot sensor
Luciano
Luciano
35
Screenshot_2017 -11-08-21-38-14-1.png [53.19kb] Hello friends! !! I need if someone can give me a connection diagram of a photocell to four lights that turn on the same key. . I wanted to connect a kalop photocell with sensor so that it turns on and off4 lights that turn on with the same key but only turns on and off the focus to which I connect it while the others are fixed, I tried connecting focus by focus but only turn off the focus to the I connect it. ...thanks
Ennio Montenegro.
Indicate the type of spotlights and the power, to indicate if the photocell allows to command the charge of the 4 lamps. If feasible, the bulbs have to be connected in parallel to the focus that does work. Indicate the type and power of the lights you will use.
agustinp
agustinp
2.247
Hello, if the 4 lamps add less than 1.2kW, this diagram can be used without problems. In phase (black), the switch would be on
Ennio Montenegro.
Hi Agustinp
Being with reactor the lights and adding 1.2KW. It would be advisable to use a contactor, don't you think .. ??
