Complex matter haha to see .. I have to place an air conditioner 20 meters from the main board, I must calculate the section to avoid voltage drop. Assuming the air spends 10A the bill would be
K = 2
I = 10
L = (count 20 or go to km?) Would it be 0.020?
R = here would be the resistance of copper, right?
X =
Phi =
Where I don't complete I don't understand, sorry if it's annoying to explain and I don't understand, it doesn't seem easy. The calculator uses it but the last two options, power factor and Correction coefficients have several options, I don't know which would be the one indicated.
It will depend on the type of installation and cable you use
You can do it with the calculator
In cos phi place 0.85
In correction coefficient if there are no other circuits in the same pipeline it goes 1
In voltage drop place 5%
The calculator will recommend several possible options and say the voltage drop
