Hello, if you want to do it well, and you still do not have a court as p to calculate it by eye, you will have to take the effort to imagine the consumption of your house (in potential, after calculating ampers), both p the cable and p the protections
The 2.5 for lcues and shots is fine, in fact it complies with the recommendation,
The 6 q opinene others but for an air seems excessive, I do not know if you put more.
The q goes to the meter must be four.
The ground wire must be equal to the thickest wire you have (in your case if you continue with 6 mm2 p the air, you would have to use six, which is a lot).
In clean, get more or less than the consumption you would have and with that look for the table of what amperage bank each section of cable. From there you take out the circuit breaker (almost always 40A is emitted) and the two thermal
