Household Electricity
Query Booster
solicitoya2015
I have a 9 KVA automatic voltage booster installed after the circuit breaker and for all the consumption of the house, but the voltage is dropping a lot and when I measure it with the tester it marks me 150v with an elevator included, the question is if the elevator I place it exclusively for air conditioning. of 4500, with which I have problems, I can have more performance, thanks
electrophotographer.
I guess you are talking about 220V line for your property. If your output reading is really 150V that is dangerously low. If you reconnect the Trap for only the Air Conditioning, the 9KVA available should be sufficient to maintain the necessary nominal voltage. Of course, it measures what happens with the line voltage available for the rest of the equipment without the connected connection for the entire property.
Edurau
Edurau
835
The first thing we should know is, what is the input voltage ?, because assuming that the elevator is doing well, it should be less than 80 volts, in these conditions cut the current and start crying, because it has no solution, but if It's bigger than the elevator gives you, throw it away. and find another one. From there you can comment.
Your question of using it only for AA. It makes no sense because it will end up burning. luck
nastor
nastor
17.232
Hi A 9 kva lift is suitable for a constant consumption of more than 30/35 amperes, which is sufficient for a medium-sized house with several air conditioners; keep in mind that an air of 6000 fridges (large as for a dining room - being important) consumes approximately 11 amps. Something is wrong with the tension elevator, it should be enough for a 120 meter covered house, and keep more than 200 volts in line. I summarize, ask about the elevator regulation, since it may be badly configured, or you take it to where it has been sold and it claims. regards
