Household Electricity
Main and sectional board
alejandro9649
Good colleagues: I have a question about the assembly of an electrical panel. It is a commercial premises with the single-phase meter placed on a wall above the municipal line, and on the inside of the premises there is the main board with the thermomagnetic key and the differential switch, but there are also 2 thermal keys on the same board. lighting circuit and outlets. The query is whether it is correct that the main board also functions as a sectional board or if it is necessary to separate them. This is the only board of the premises. I thank you for the help you can give me.
elektomaq
elektomaq
62.202
Hi It is correct, as long as the main board is inside the premises or housing, it can also contain the terminal circuit thermals Cheers
alejandro9649
Thank you.
