Household Electricity
Electric general electric counter current box
Jesus medrano
My box of current cutters has a strange problem the countercurrent that I use for my stove 220 volts 40 amps works fine but when I connect the other one to the dryer 220 volts 30 amps it works but does not generate heat and if I exchange the wires in the countercurrents the dryer of clothes work and the stove doesn't
Hi. What do you call it does not work well? Give data of the device or upload a photo of the area in question. Regards
Jesus medrano
Well I think the problem is that of a breaker because as I explained it is a 40-amp breaker when putting on stove wire works well and when installing another breaker for the clothes dryer everything works in the dryer but blows cold air only and when exchanging the wires in these 2 breakerla dryer works perfectly and the stove that is electric stops generating heat
chester milton
Hello Jesus. as I understand you have 2 devices connected to 2 short currents. C1 and A1 work well. C2 and A2 do not work well. being a for device and c for power failure. when you roll or swap C1 A2 it works fine and c2 A1 doesn't work. Then check the connection of the short circuit breaker # 2, the cable, the connection of the current cutter or the same connection cable to see if it has problems also check the neutral has or if they are two active faces, Apparently you must replace or adjust the cutter 2. I hope I have placed some light on your doubt. Comment
Jesus medrano
I already bought the 2 new breakers but the problem is the same
Jesus medrano
And I don't understand why the 2 devices only work well with the same breaker
elektomaq
elektomaq
62.202
Hello Obviously if you already changed the countercurrent, you should check the interconnection between the two, that is, the driver that feeds these breaks, surely the one of the second break is somewhat loose or its connections in poor condition and generates a significant voltage drop If you have no experience in these areas, I suggest you turn to a professional regards
