Household Electricity
Thermomagnetic wrench
Miguel Batista
Hi, I'm in a remote place, I have a work team that consumes 12 amps, has a thermal of 15Amp. And sometimes it jumps when it turns on. I think that the peak of the motor when starting exceeds the thermal amperage. To solve momentarily, since I do not have thermal of greater amperage, and I do not have near house of sale of electricity. but if I have another 15 amp thermal. Question can I divide the voltage between the two thermal of 15 Amp. They can both thermal 15 amp. can you cover this eventuality
Ennio Montenegro.
How do you want to divide the tension between the 2 phases .. ???
Ennio Montenegro.
Michael It can consume 12A, but have a higher rated current. The thermomagnetic to be used must be class C, which operates between 5 and 10 times the nominal current. What is not clear is whether it operates immediately at startup or after a while. You do not mention whether or not the equipment has an overload protection, since the thermomagnetic is to isolate the circuit from a short circuit.
Miguel Batista
Thanks Ennio, I comment:
the thermal ones are of class C of 15Amp.
The motor / compressor starts without problems, when it reaches the maximum load for, but after a while, when it wants to start again the thermal jumps.
The motor has thermal protection.
As I am more than 50 km from the city, and I do not go often, I wanted to know if I can connect two thermal to the motor circuit and if that is effective.
Ennio Montenegro.
Miguel commented that the fault could be in the pressure switch, which would not be venting, so it tries to start against the pressure of the tank and fails to start. You can corroborate this, if when trying to start you only hear a hum. When unloading the tank, it would restart normally. The problem is that if you increase the capacity of the thermomagnetic or if you derive (divide) the current with 2 thermomagnetic, it will not operate due to overload and I know that it would burn the motor.
elektomaq
elektomaq
62.202
I agree
perhaps regulating the pressure switch to start with less pressure
Ennio Montenegro.
Hi elektomaq, the problem of reducing the starting pressure would also reduce the final pressure since the differential (hysterysis) of the pressure switch cannot be increased more than a certain value.
Miguel Batista
Thank you Mil, Ennio and Electromag ... I'm going to disarm the equipment this weekend, since a friend is coming to visit me and something also knows about these things. and see if there is any fault, Thanks for the help at least under my anxiety level ..... and I didn't do any messy .....
ratonelect63
ratonelect63
5.308
divide v between 2 thermals and live in a distant place ...... have a team that does not know if it is pure or pure. say divide v instead of i ... is something I don't understand mate ... maybe if an idea is explained well from the forum
