Household Electricity
Good I have an inverter trace ur 1000w 12v
Reidy Baes Flores
The problem is that when the light goes out the inverter lasts some 15 minutes and the lamps go out flashing when it is about to turn off. I hope you can help me
Chuca
Chuca
394
Friend little info you contribute but we are almost sure that you have too much consumption connected, accept solution and we can see that it can be commented
Hi. Did it work well before? Have you controlled the battery (s)? Regards
Reidy Baes Flores
If it worked fine before
