Household Electricity
Electric shower
Fibrero
I can connect to the ground that I already have at home the land of my electric shower
Fibrero
or I must place another ground rod for the shower apart from the one at home
creysler
Yes, with full security.
Fibrero
If you are sure that I can connect it to the one I already have at home?
Hi. You can connect it to the land line of the house without problems. What if, you should check if the existing earth is working but you can connect the shower without problems. Regards
Fibrero
Thank you
I can tie it from the earth cable Q passes x the fuse box
Fibrero
And how to know if the earth is working that I already have
edugues
edugues
128
It is very important that you have good soil, to test it you need an instrument. seeks to test grounding.-
As to make a test without having a specialized device you can connect a considerable load between the phase and the earth. If it is a better reflector even. If you have a differential, it will jump immediately. If you do not have the reflector, it should light up with all its brightness emulating as if there was a connection between phase and neutral. If it does not shine or shines little, it means that the PAT is not operational. Regards
