A magnetic thermos, even if it is 10A, has no effective protection for this equipment. If you want you can replace the thermal of 20 that is on the board, with a 10 (only if the circuit is independent for air) or 16 if there are other loads associated with the circuit. This is to have a better protection of the equipment installation and achieve greater sensitivity,
put a second thermal on the side of the equipment, it is useless, rather change the one on the board, apart it will be more aesthetic,
regards
