Hi esteban 2016 I tell you about your problem: the solution that gives you servimat 1 is really right everything depends on the client too, and his disposition with the money , however you have 30 LED strips according to what you indicated, normally each led strip comes from 5 mtrs and consume an average of 2 amps for each strip, but in the end you say that they are about 30 meters that would be about 6 led strips = 12 amp would be the total consumption, so you should place a larger capacity battery in the ups if they want to last at least 2 hours on that you can add a photocell of those used to turn on exterior lighting systems in buildings X , making an extension with cables and 2 you take a female and the other male to place it at the exit of the ups, (only if the corridors get external lighting if you do not leave it directly because by day or night the aisles will always be dark ), and voila calculates that with any battery d The normal vehicle will work excellent for you because the batteries in the ups that deliver the most are 7 amps, I hope you find it useful, thanks for taking the time to read.
