Household Electricity
technical consultation .......
mast22
mast22
3
hello I have TWO line for each air with 4mm cable with 20A BIPOLAR INDIVIDUAL THERMAL AND ANOTHER 2.5MM LINE FOR GRAL USE TAKES WITH 16A BIPOLAR THERMAL ALL GO WITH TWO SINGLE PIPE ONE FOR EACH AIR AND THE OTHER FOR YOU TAKE THE GRAL USE BUT IN A SECTION I HAVE TO TAKE IT OUTSIDE, IT GOES EMBUTIDED UNTIL AN OCTAGONAL CASE AND FROM THAT BOX GOES OUTSIDE WITH A PIPE OF APPROX 1.5MTS UNTIL ANOTHER OCTAGONAL CASE AND AFTER GOES A PIPE FOR EACH AIR THE OTHER FOR THE GRAL USE TAKES. PROVIDE THE VOLTAGE OF THE 220V APROX JACKS UNDER THE THERMAL AND REMAINS WITHOUT LIFTED VOLTAGE AND I HAVE VOLTAGE WITH EACH OF THE AIR THERMALS I DO SAME WITH THOSE OF THE GRAL USE. I WANT EVERYTHING MY CONSULTATION THAT GOES OUTSIDE IN THE OCTAGONAL BOX THAT I HAVE THE THREE LINES MAY BE THAT BY SUPPORTING THE COMMON SEARCH ON THE CABLE WITHOUT PELAR THE LAMP IS ONLY NOT ON ALL THE CABLES ONLY THOSE THAT THE PHASE OR NEUTRAL , ALSO SUPPORTS IN THE OCTAGONAL BOX OF CHAPA TO SEE IF THE SAME HAPPENED AND NOTHING HAPPENS ONLY IN THE CABLES OF THE PHASE BUT I MEASURE IN THE TAKES I HAVE NEGATIVE AND POSITIVE WITH THE SAME LOOKING FOR EVERYTHING IN THE SHORT THERMAL THE MIDO WITH THE 0V TENSION OF LIFT VOLTAGE AND I HAVE 220V APPROX VOLTAGE. WHAT CAN BE.
elektomaq
elektomaq
62.202
Are you likely using an inductive pole finder?
eldona
eldona
296
Hi Mast. The truth is that I have complicated to follow you in your description of the problem. If I misunderstand it seems to me that you are consulting for an induction issue, where you measure a cut line and the tester or pager indicates you as if you had tension. This is a phenomenon that occurs when the cables run along a pipe shared with other cables that have tension and this is induced in the cables of the line that is out of service. There are testers that measure with low impedance and consume this phantom tension. If you do not have it, you can connect a lamp and you will see that it does not light effectively. I hope to answer your question, Regards.
Alectric
Mast, good afternoon. As for your query, the same thing happens to my colleague Eldona. It is very confusing and very complicated to understand the plot of the pipe on which some of the power lines travel. It would be important to help you, to draw a simple scheme above all, coloring the wires. On the other hand, I interpret that the external pipe is metal? Junction boxes are too. Regardless of looking for a solution regarding the tension you measure in the cables. It is absolutely essential that the outer pipe and its junction boxes are made of NOMENCLED PVC material. If you send your scheme we can definitely find a solution. Greetings
