Household Electricity
I have electricity at the faucets and in the hot water tank (it is gas
nesnq-ar
Hello friends, I will report the problem so you can give an opinion. They are 2 stores of 3.50 meters. wide each, both have separate light meters. One night I arrive I open the bathroom tap and it gives me a little electricity, I start testing the thermos which is gas also kicks me by touching the inner part. Then under the thermal key, I measure and mark suppose 10 I don't remember exactly, (I measure with a tester, taking the tip with my hand and the other tip goes to the artifact). If lowering the general thermal of my premises, there is still electricity in the pipes and artifacts, The loss must come from outside. Under the thermal of the street is what provides the energy company (edenor) and the continuous loss is to say the artifacts have energy with everything turned off and disconnected. Under the thermal of the emitter of the neighbor and the loss disappears, it is clear that the loss is in the store the neighbor, after many inconveniences with the neighbor "said he was not lost" could Enter an electrician and check that the loss came from the premises next door, and I solve it. I do not know how, this was 3 months ago we never had problems again, until today that the devices had electricity again. I cut the energy of my store, there are still losses in my store. Two questions, what can it be? Who should I go to so that the neighbor is forced to verify its installation? : -o
Germàn LB Service
It could also happen that the one who went to correct the problem only changed the phase wires to neutral and visceversa and now it is finished triggering the problem, I have seen several do a quick job, collect and not return.
elektomaq
elektomaq
62.202
Hello Most likely, your neighbor is deriving the discharge to ground through the water network or has some connection for energy theft. Anyway it is illegal and your neighbor is obliged to put things in condition and forever You can denounce simultaneously in the municipality (electromechanical, cadastre and safety and hygiene offices) and in edenor Regards
nesnq-ar
Thanks elektomaq, I will report this program in the municipality ..
