Household Electricity
Cover ceiling light hole
PickyE
PickyE
35
Good I have to cover a hole of ceiling light, since the plaster fell off when removing a ceiling and a hole was left a little bigger than it was.
tecnico54
tecnico54
22.006
upload a photo of damaged area
nastor
nastor
17.232
Yawl Replace the missing material with plaster or interior Poximil; you can cross some fine wires to support the material if the hole is large, first load the plaster to make "body" in the hole, always slowly, then throw (maximum 10 minutes), more diluted loads to finish. Regards
Hi. You can place a plastic container as a mold for the box and add the plaster or whatever you are going to repair. Before it dries remove this container and the mouth of the ceiling will be finished as original. Regards
