Household Electricity
Contactor and voltage regulator
Marianix
Good, how are you? My query is something simple for those with knowledge. I have read there that I can use for example a 230v voltage stabilizer whatever the WHOLE home is for. But using a CONTACTOR for the consumption of the house. Is that possible? I mean, from my point of view, the stabilizer limits consumption by its own capacity. P.S. In my Uruguayan country the 2 poles of monophasic have 220. We do not have a live and neutral greetings.
elektomaq
elektomaq
62.202
It seems to me that there is a confusion in the consultation ... It is being called stabilizer to something that is not a stabilizer ... but rather it is a tension protector. anyway.... if it is a stabilizer it is limited by its nominal power. It will not be exposed to more power and cannot be achieved with a contactor if it is a voltage protector, these only sense the tension and the power is limited only by the capacity of its contacts. In this case, if you can use a contactor to protect the most consumed devices Stabilizers can protect themselves when the voltage is outside the operating range but that does not mean that working as a voltage protector is two different things. regards
ratonelect63
ratonelect63
5.308
it is not understood ... but the stabilizer only stabilizes the network v. and has a capacity limit here in uru. or arg.a contactor so that does a contactor become a yes or no or is it nothing or the whole load of blow ..... it makes no sense
Marianix
I expressed wrong. I want to expand the capacity of my 1000w high and low voltage automatic stabilizer with a contactor. Connected the consumption of the house to the contactor and the stabilizer as power to the contactor. Is it possible to increase the capacity of the stabilizer?
ratonelect63
ratonelect63
5.308
no companion you have a thousand available and surely there are a thousand liars ... I still do not understand bo for the contactor do you have to go to the real one, go load and see how far it lasts ... when it no longer sinks and starts to fall into v , even woe and no more.
Contactor would hit him with a blow hammer, he doesn't go and no.
ratonelect63
ratonelect63
5.308
it is not necessary for you to explain it to me, it does not make sense, colleague, that is clear.
nastor
nastor
17.232
Hello The contactor is only used in PROTECTION (trip) of high or low voltage, when the nominal current of this device does not allow to handle all the consumption by its contacts; the case that you mention, as Mouse-greetings well says - you only need to connect the rear stabilizer to the main board, as it does not connect, or disconnect anything, it does not need a contactor. Regards
Hi. I leave you an image. This is what you need? Regards
