Household Electricity
New grounding
Horacio Lena
What is the possibility of placing the ground javelin in the autumn sector that is not close to the sectional board or primary board. What happens is that it is in an area that I don't think is very conductive because of the amount of cement and construction that it has around. On the other hand, however, if there is land on which to place the inspection box and javelin with a neat and correct connection. Thank you.
Nelson33
Nelson33
164
hello, it could be placed no problem, always and when this is all communicated in the current sockets and throughout the house Regards.
Hi. You have to see the regulation of your area. Many companies such as EPEC require that the PAT be visible at the foot of the meter. For technical reasons there is no problem to do so. Regards
nastor
nastor
17.232
Hello There is only one drawback, and that is that from the ppal sectional board all circuits with their respective land lines come out; if you place it at a far end you should think about bringing a direct collector land line to that distribution of a considerable section (6 mm), this to be effective in the face of a need for significant leakage. With a drawing I will explain myself better.
nastor
nastor
17.232
In case it is not clear, in most cases, what you propose is counterproductive, something like "the remedy is worse than the disease"
nastor
nastor
17.232
I understand that we speak of the internal javelin and does not refer to the rush, which by regulation must be at the foot of the meter.
