Household Electricity
Cable gauge
heladera 730
Goodnight. I am putting together a video illuminator with 8 white LED bulbs of 15 watts each. That is a total of 120 watts. I need to use a calbe 10 meters long. I usually put any cable and it's fine. Now I would like to know what the appropriate measure is.
elektomaq
elektomaq
62.202
Hello If you are from Argentina, for a purely normative issue, at least 1.50 mm² regardless of whether the consumption applied is very little for the switches you can use 1 mm² Regards
nastor
nastor
17.232
Hello Do not complicate, use an extension or extension of 3 x 1.5 mm² round cable, with a polarized three-legged male tab, a thermal of 2 x 5A in the furniture for protection and sectioning, from there although you can use a little less, My advice is that you continue using flat cable of 2 x 1.5 mm² plus ground in the furniture, either stapled or in cable-channel, quality switches the same as the lampholder. The round cable workshop (TPR) is not suitable for fixed installations, but in this case you have no practical option, however be careful not to get hurt.
gustavo plc
With a cable of a section of 1.5 mm you have enough left over with 10 meters long you still have enough left over.
