Household Electricity
Home Board - Board Design
condoritocba
Hello, my query is the following, I am making, or to be done, the boards of a house of 200m2 on 2 floors, the design would be the following: Board 1 Ground Floor: Bedroom, entrance hall, dining room and staircase. 3 circuits: A: Lighting, 1.5 mm2 cable B: Sockets, 2.5 mm2 cable. C: AA: 2.5 mm2 cable. (for 2 AA boys, in total 2400 watts). Board 2 Ground Floor: Laundry, Kitchen and Garage. 2 circuits: A: Lighting, 1.5 mm2 cable B: Sockets, 2.5 mm2 cable. Board 3 Upstairs: 3 Bedrooms. 3 circuits: IMPORTANT: this board is connected to the ground floor board 1, that is, the cables reach this board from the board 1) A: Lighting, 1.5 mm2 cable B: Sockets, 2.5 mm2 cable. C: AA: 2.5 mm2 cable. (for 2 AA boys, in total 2400 watts). The query is about the Thermal Amps and circuit breakers for this design, if you can help me very gratefully.
elektomaq
elektomaq
62.202
For lighting 10A for 16A sockets For AA 20 A It is not very clear about the total 4000W You must keep in mind that each board must have a header switch and each sectional circuit must have its thermomagnetic Comment this is the board scheme to be made CP is the main circuit that goes from the meter to the board in the pillar. 10 mm² cable TP in the following order: general thermal 50A differential switch 63A / 0.03A thermal CS1 40A cable 10 mm² to TS1 thermal CS2 25A cable 4 mm² to TS2 All interconnections must be made with 10 mm² or 63A combs CS1 cable 10 mm² CS2 cable 4 mm² TS1: header thermal 50 A Divide into 4 circuits: 1- TUG Thermal 16A cable 2,50 mm² 2- IUG Thermal 10 A comes cable 1.50 mm² 3- AA thermal 20 A out cable 2.50 mm² 4- TS 3 thermal 32 A cable 6 mm² comes out interconnections must be made with 63A distribution bridges TS2 header thermal 25A two circuits: 1- Thermal TUG 16A comes cable 2.50 mm² 2- 10A thermal IUG out cables 1.50 mm² CS3 cable 6 mm² TS3: header thermal 32A 3 circuits 1- Thermal TUG 16A cable exit 2.50 mm² 2- Thermal IUG 10 A comes out cable 1.50 mm² 3- AA thermal 20 A out cable 2.50 mm² the distribution can be made with 6 mm² cables or 63A distribution jumpers
condoritocba
Thanks elektomaq for your response, the AA thing I have in mind that I cannot overcome those watts for the 2.5 mm cable section. Your answer is very useful but, what would be missing is:
The thermal that goes at the entrance of how many Amps would it be ?.
The circuit breaker that goes before the 3 circuits of how many Amperes and MiliAmperes would be ?.
I also want to put a circuit breaker for each board, how many would they be? And if it is necessary to have one for each BOARD ?.
The thermal and circuit breaker at the output of board 1 to board 3 of how much would it be?
Thank you in advance for your time.
elektomaq
elektomaq
62.202
It is necessary to clarify the air conditioners well since they can be relevant in the election. The doubt comes that 2000W airs are not common
elektomaq
elektomaq
62.202
It is also not clear if you are talking about 2000w of capacity or electrical power
condoritocba
I apologize elektomaq, spoke of refrigerators, the power is 1350 watts each.
elektomaq
elektomaq
62.202
No problem ... I spend the normal consumption per team
2250 frig consumes about 900 W
3000 frig consumes about 1200W
4500 frig consumes about 1700W
Question outside the air: is the main board separated from the first PB board?
condoritocba
Hi, there are 2 main boards that come from the entrance from the street, Board 1: Bedroom, entrance hall, dining room and staircase; and Board 2: Laundry, Kitchen and Garage, there is also a 3rd Board on the top floor that comes from Board 1. That's why I wanted to know:
The thermal that goes in the entrance, in the pillar of the street, of how many Amperes would it be ?.
The thermal and circuit breaker at the output of board 1 to board 3 (upstairs), how much would it be ?.
elektomaq
elektomaq
62.202
The main board is the one that is next to the meter on the pillar
Two more questions
What is the distance between this board and each board of the house on the ground floor
elektomaq
elektomaq
62.202
Do you have single-phase or three-phase?
condoritocba
Well, what happens that the 2 boards below come from the pillar, that's why I say that the 2 are "main".
From Pilar to Table 1 there are approximately 6 meters.
From Pilar to Table 2 there are approximately 10 meters.
condoritocba
Single phase
condoritocba
Hi, it's just single phase.
elektomaq
elektomaq
62.202
Excuse me today I couldn't do your thing. Tomorrow I try to do
condoritocba
Yes, no problem, I thought my answer about three-phase or single-phase was lost, that's why I repeated it. Thank you!
elektomaq
elektomaq
62.202
There edit the response by adding the information
Any questions comment
The differential switch with one only reaches, if you want one per board you can put it (comment)
The protective conductor (ground) must be a minimum of 2.50 mm² or if the line conductor is of greater section it must be of the same section as these
elektomaq
elektomaq
62.202
It is an installation that requires three-phase both for consumption and for the degree of electrification (high)
condoritocba
I really appreciate the time you took to generate a solution, thank you very much !, I will take into account everything you say. Thanks again!!!
Greeting!
