Household Electricity
Meter problem
eltiki
eltiki
12
A pole of the thermal that is inside the meter was burned, taking into account that inside the house no thermal jumped even did not jump the main thermal, why is it? I clarify that a hair dryer was plugged but it is the first time that happens !!
Hi. This thermal is actually the one that supports all the load, however small or large. If their terminals are loose, there is a false contact with a resistive point that generates heat and what happens to you happens over time. This is the competence of the company. You must give notice to them. Regards
favallpa
favallpa
2.523
Most likely ..... lazy terminal. With the voltage drop it gets very hot.
abou-assali
In addition to the hot spots, it is certain that you have a poorly calculated load imbalance and protections, I recommend you measure the current at full load with all your equipment, most likely that general power supply is overloaded.
Hi. The friend talks about the thermal cutting and general protection of the meter, not of an outlet. On the other hand, in a single-phase system there is no load imbalance since the phase is only one and everything is loaded on it and the neutral. Regards
abou-assali
When a project of a single-family house with this type of load is carried out in Venezuela by CADAFE Standards, its Meter has to be Bifasic, where we have branches of public lighting, general-purpose outlets, special-purpose outlets, that's why I'm assuming this scenario, I never thought of a shot, but of a Bhasic Breaker overloaded by a phase, in addition to its hot spot, I hope it has made me understand, greetings
