Household Electricity
Automatic tank type tanza
albarracinmauro
hace 6 años
hace 6 años
I installed the automatic tank, the one that has the tanza, when the tank is full, cut, but when it empties, the pump turns on two minutes and turns off, it would seem that the lower bottle rises with the water and cuts ... Why will it be ? Thank you
Edurau
Edurau
835
hace 6 años
They are changed position, the top one is down, the bottom one must be loaded with water and the top one empty, when the bottom one weighs, (it should not be regulated at the bottom, but 1/3 or 1/2 of the tank ), the engine starts, and when the water reaches the top, (at 1/8 or 1/10 dfel tank), it floats and relieves the load, then stops the engine. luck
Edurau
Edurau
835
hace 6 años
I have had that system for 46 years in my house, and it only fails the tansa is cut, once every 10 to 12 years, there are other systems, Peeeerrrroooo, my neighbors are working in the tank every so often. luck
albarracinmauro
hace 6 años
The one below is with water and the one above is empty.
nastor
nastor
17.232
hace 6 años
Hi Mauro, I deleted the comment as wrong, colleagues agree that the buoys are going as you said at the beginning.
ova1999
ova1999
477
hace 6 años
hace 6 años
friend, check that when the water enters the tank the jet does not give any of the buoys, as they start dancing and cut and start alternately, luck!
albarracinmauro
hace 6 años
Thank you very much, it was what you mentioned! The problem was the proximity to the water jet. I already solved it, and now no problem.
Until next time!
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello The buoys are hollow like a glass. The one below the hole goes up and full of water The one above the hole goes down What can happen is that the lower buoy is very close to the stream of water that falls and the same gush that makes the water lifts the buoy more than the bill and causes it to cut. It is solved by relocating the farthest automatic or placing a pipe that directs the water jet down avoiding the movement of water Regards
nastor
nastor
17.232
hace 6 años
Does Fibosa 600 have inverted cups?
elektomaq
elektomaq
62.202
hace 6 años
I do not remember but I always put them together, whatever the brand, I never had any problem except the last two that I placed (in the same circuit) that is seen to have played a bad game and in a matter of a couple of months they called me to change first one and then the other, both had broken the microswitch, replace them with submersibles and never again
elektomaq
elektomaq
62.202
hace 6 años
If you use logic ... The buoy below has to go with the hole up so that it stays full of water and makes weight
And the buoy above has to go with the hollow down so that it lifts the weight since when covering the water inside the buoy an air chamber is formed capable of lifting the buoy below and inverting the switch and also preventing it fill with water since this happens the system does not work
elektomaq
elektomaq
62.202
hace 6 años
In short ... Both holes faced
