Household Electricity
electricity + tv + phone
andresfigueroa2015
hace 6 años
hace 6 años
Good Morning. I have to complete a complete installation in a house and they left me some plans showing TV and telephone quality facilities. I have some basic ideas on the subject such as, for example, that go in separate pipes of the electrical installation, but I don't know how my installation connects with the cable provided by the TV and telephone company. how to make the derivations correctly, that is to say if in the house there is TV output in the two dossiers how I do the joint if it is done. if you can give me some general guidelines to be able to do the job. I hope you can help me. thank you
fabi1965
fabi1965
1.293
hace 6 años
I recently did something similar to what you have to do with respect to the TV the owner needed to connect 4 TV I did this on the roof I installed a box of 10 x 10 pvc used for outdoor use and I brought them the corrugated pipes of each TV Pass the coax cable to each one, place a 4-way TV splitter and place it inside the box and let the company that distributes the TV bring me a coax cable from the street to the box and connect it to the Greetings entry and I hope my answer will help you
nastor
nastor
17.232
hace 6 años
Upload a floor plan indicating available cable entry and TV locations, and tell us if you have space in the ceiling for pipe laying
nastor
nastor
17.232
hace 6 años
hace 6 años
Hello The TV line goes with the TE line in a pipe generally separated by a ceiling using 25 mm rigid pipes. Boxes other than 10 x 10 x 7 cm are used, the TE is spliced in these boxes, the TV goes directly from the input box to the TV, this in every place there is one. The TV input box should be a few meters from where between the cable and the phone, the minimum dimensions are 12 x12 x 10 cm to put a splitter (TV) Depending on the number of televisions, it is the complexity of the installation, and sometimes it is very complex. Comment like this wide
ydd:alualo
ydd:alualo
2.847
hace 6 años
As you comment, the street entrance for TV and Telephone, is a first record with the ability to insert the main line dividers, to the different branches within the home, almost resembling a small main board, greetings
andresfigueroa2015
hace 6 años
okay. It's more or less the way I thought it was but I wasn't sure. Now if the company that provides the TV cable charges for mouths, that is, for connected TV, they do not know how much mouths the house has. That does not generate inconvenience between the company and the owner of the house or is it something that escapes what we can do?
If I misunderstood, the supplier must connect from outside with a cable that the installer should leave in a 10x10 box? or with pipe and a cable that would look good?
nastor
nastor
17.232
hace 6 años
That happened before in my payments, now they don't try to charge for connected TV. Anyway I tell you how it is done, you take the three or four TV cables you need to the main drift box, logically you will not pay four signals (that's a fan), so you ask the installers of the cable that will connect you to the Living or Dining Room (previously identified) and that the other three will connect them in the future; well, get a good chair and wait for you sitting, so you don't get tired ....
elektomaq
elektomaq
62.202
hace 6 años
If you are the electrician who does the installation and you are not the homeowner, as interpreted in the initial consultation, you should not mind if the cable video company charges by signal or mouth
nastor
nastor
17.232
hace 6 años
I disagree with you elektomaq, personally I am always at the service of my client, who hires and pays me, and not to make the fat broth to the abusive cable companies, or whatever. This goes beyond a legal issue, since many of the limitations or conditions in these types of provisions are outrageous because they are monopolistic services, so one advises how to avoid these virtual thefts.
This goes beyond a technical issue, it is professional ethics to discern what is fair or not, and act accordingly. Certainly opposable and debatable.
elektomaq
elektomaq
62.202
hace 6 años
That goes into each one but if one is an electrician the main problem of one is that the client is satisfied with one and obviously that he pays one what is agreed upon .... Then if the client has to pay for a TV or for 4 it is The client's test and life taught me that if they don't ask me, I won't get in. I have lost works by advising in the best convenience of the client.
If they give me a map to put 4 TV mouths I put 4 TV mouths and then the client will know if it connects all together, or connects only one, I do not go home to watch the games
elektomaq
elektomaq
62.202
hace 6 años
It does not seem to me that one is better or ieor professional or person for that. What if, you tell the client to connect a single TV and if he listens to you you will make a single mouth losing the other three ... it has happened to me many times.
elektomaq
elektomaq
62.202
hace 6 años
On the other hand, if the client wants to place a premun HD service, he will have to put everything in one and declare all the mouths. Companies charge the service package and an additional one for each extra deco and it is not for much but if you do not put it, you do not have it
nastor
nastor
17.232
hace 6 años
It is personal, it does not mean that it is more professional or not for that. And sometimes they pay you badly, it's also true; but if you ask me I always advise in favor of people,
elektomaq
elektomaq
62.202
hace 6 años
I used to be the same, but the issue is that work is scarce and in a big city like Buenos Aires, the little that comes out you have to take good care of it because you neglected a second and another comes back and slept. So when you wait 4 mouths you have to try to do it without going on advice. The last time I had to do something similar was for a house I had to lower 6 mouths and I had budgeted at that time 1600 pesos. I started giving him advice to pay less and he paid less. I ended up putting 1 mouth alone which charges 200 pesos
elektomaq
elektomaq
62.202
hace 6 años
I lost a laburo for 1400 mangoes that at that time was good silver and everything for what?
elektomaq
elektomaq
62.202
hace 6 años
After the company went to connect the cable I saw another working on the installation, I know because I spend every day in that house
ydd:alualo
ydd:alualo
2.847
hace 6 años
Hello friends, split my dear friends, nastor and erlektomaq, I tell you, both are right, I and any electrician, work to earn money, no applause, but when possible, he commanded things, (hence the recommendations). Companies are worth little to deceive the client and say that for each extra device you use, you have to pay them an extra of the contracted amount for only 1 device, but they don't give me the extra device, I have to buy that one, so I want to because I am going to pay a separate rent. The signal splitter is the one that gives the required power, not the company, and that monitor, ...
ydd:alualo
ydd:alualo
2.847
hace 6 años
He said ... and that divider is a small attachment, very low cost, which can be acquired freely in any electronic house. So, telling the client that the company only connects to only one exit, it is correct, then, one makes the divisions, for a fixed cost, not monthly as income that the companies make. And let the client understand it as he can and according to his reasoning, it is also valid, even if the only gains are lkos of the company, (unfairly). So we discussed it, better all friends, greetings. alualo.
nastor
nastor
17.232
hace 6 años
Hello Alualo, if I make four outputs I charge the four, but as you say, I advise to connect only one when the company leaves with the "fan" of wanting to charge for connected TV, then call me and place the frequency divider.
elektomaq
elektomaq
62.202
hace 6 años
hace 6 años
Hello for the choice of the box you must make sure what type of cable service is the one that is contracted, if it is with the internet they carry some filters and requires a somewhat larger box (15x10) From the box you lower a pipe to each mouth (TV) and leave a guide past since they are the ones that pass the cable from them (they do not admit existing cables) For that same reason I recommend that the telephone cable be with a separate pipe to avoid possible damage. On the other hand it is better if one day they have to rewire one of them If two mouths are close enough you can use a single pipe through two cables together or using or passing a single cable and using modules with branch Regards
